Discuss Who Polybonds New Plaster???????? in the Canada Tile Advice area at TilersForums.com.
Yes plaster needs priming, but not with PVA, in any form.
Use a proper tiling primer like an SBR diluted as per instructions.
Better still, take guidance from the adhesive instructions that u intend to use.
That way if there is ever an issue then at least u've followed instructions.
Many primers are different colours, with that adhesive manufacturers can identify their products instantly.
So if u mix brands, they can walk away without responsibility.
Reply to Who Polybonds New Plaster???????? in the Canada Tile Advice area at TilersForums.com
  • Sticky
Hi all, Old bathroom becoming wetroom, two of the walls were dot dabbed with the water resit...
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
First of all, I'm sure this question has been asked a thousand times so apologies in advance! A...
Tilers Forums on FB
