Z
zygo
I have posted (elsewhere on this forum) a project to tile a small room in granite. The subfloor is about 80mm sand/cement mix laid on 80mm Celcon insulation board, laid on DPC placed over an existing concrete garage floor (probably 100mm deep).
I plan to use Mapei grout and adhesive (after laying a screed on a primer). I think the adhesive and grout come in quick set and standard set (I'm a slow and fussy DIYer, so I'll be using the standard set type), and also in flexible and ... rigid/hard(?). I am advised to use 3mm spacers.
Given the sub-structure, which would a professional use? And why?:huh2:
Thanks everyone. Of all the forums I've visited on this project for different trades, this is easily the most helpful.
Z
Z
