Discuss Why Stagger Joints for Mosaics? in the British & UK Tiling Forum area at TilersForums.com.
Branty
To blend the the mosaic sheets together better as sometimes you will be able to see the individual sheets when the job is completed. I prefer to remove every othe mosaic so that the sheets interlock creating a seamless effect.
Now thats a top tip.
I for one never understood the need to stagger sheets. The 1st big mosaic job I did, was with a old time fixer and his son. We did 200sqm's, and they didn't stagger one sheet, but they did take their time, and the job looked great.
My argument is, you can't stagger the sheets horizontally, and vertically, so why bother.
I do like Sir Ramics idea though.
Gazzer
I guess its each to their own with this. years ago when mosaic was VERY popular i would fix the sheets that had been pre prepared as i have stated. Thats the way they came from the factory, so i continued this when doing other mosaics since. Yes its time consuming if the mosaic is small but not too bad on the larger formats. Dont forget that the price given would have included extra time needed to do this.
Spud
staggering sheets of mosaic was adopted because on large mosaic jobs several different tilers might work in one area as you all know when you work with other tilers we all space our joints slightly differently by staggering joints you are governed by the next sheet you are fitting therefore keeping the job more uniform and allowing others to pick up from your work with out seeing the day joint
Reply to Why Stagger Joints for Mosaics? in the British & UK Tiling Forum area at TilersForums.com
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
