Discuss Wide bezel adjustable LED GU10 Electrical Advice in the Electrical Advice area at TilersForums.com.
Wide bezel adjustable LED GU10 Discussion ThreadWide bezel adjustable LED GU10 Electrical Advice
Does anyone know of a product similar to the Integral LED 70-100mm range (linked) that allows you to adjust the lamp direction? The client has a few that are shining onto paintings, but we would like to be consistent with the bezel size.
www.toolstation.com
Integral LED 70-100mm Cut Out Evofire IP65 Fire Rated Downlight
For safe, stylish and reliable lighting that's easy to install with a 70-100mm cut-out, this Integral LED EvoFire fire-rated downlight is the perfect choice. The ultra-thin 1mm bezel fits flush against the ceiling for a discreet and attractive finish, while the canless design helps the lamp run...
www.toolstation.com
www.toolstation.com
Wide bezel adjustable LED GU10 for the original thread on Electricians Forums
Reply to Wide bezel adjustable LED GU10 Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
