Discuss Will I need an expansion joint? in the Canada Tile Advice area at TilersForums.com.
Hi
This is my 1st post so thanks for any advice in advance.
I have a floor to tile through 3 rooms totalling 60mtrs sq - my 1st one this big, with plank effect tiles and through multiple rooms so Im sweating a bit. The tiles are 22cm x 90cm.
would I need expansion gaps aas the runs are more than 5mtrs?
If I put them accross the openings A and B they should not stand out too much. A should not be too tricky if one is needed as the tiles will give me a line to Silicon down/ fit a gap strip.
For B, I suppose Id have to fit a threshold strip of tiles at 90degrees ( as in yellow) to make it look deliberate and OK.
Any thoughts and advice would be appreciated.
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Expansion joints to A and E plus round the perimeters (leave gap and put skirting over). Ideally expansion should extend through screed.If expansion joints are already in screed you could also use Kerakoll Green Pro and use Silicon on nearest joint.
Reply to Will I need an expansion joint? in the Canada Tile Advice area at TilersForums.com
Hi, Looking for some advice regarding tiling over expansion joints in floor screed. I’m getting...
gamer1
I plan to lay a circa 8m x 4m patio using a concrete slab and fixing with tile adhesive. The...
6K
Hi guys, looking for advice. About to install a limestone floor. 900mm x 600mm x18mm on a 50mm...
Shropshire
What member type are you?
  1. Professional Wall and Floor Tiler
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
