Discuss Will this adhesive be ok for around wood burner insert? in the Tile Adhesive and Grout Advice area at TilersForums.com.
Hi,
I tiled around my fireplace last night with Weber fix plus tile adhesive which withstands up to 100C...I thought that would be ok for what I need it for as I'm not tiling underneath or in the actual alcove that my wood burner will sit in. However, after doing more research AFTER tiling (doh), I'm now starting to worry this won't be any use. Any thoughts? It takes 24 hours to dry fully so if I need to take them off, I'd rather do it today before i fully sets, rather than later. I'm thinking I might only need to redo the ones along the top as they'll be directly above the heat?
Reply to Will this adhesive be ok for around wood burner insert? in the Tile Adhesive and Grout Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the...
Tile Adhesive Trending Topics
Hebrides
What member type are you?
  1. Homeowner
Business Name
NA
    Votes: 5 4.5%
    Votes: 8 7.3%
    Votes: 7 6.4%
    Votes: 31 28.2%
    Votes: 14 12.7%
    Votes: 28 25.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.3%
    Votes: 18 16.4%
    Votes: 13 11.8%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
