Hi gents,
Two questions.
Is there a correct and easier way to tile above a window recess so that the tiles are level and match evenly.
trying to find a quicker solution on uneven walls
Plus, on using thin glass skirting tiles, would it be better to tile above onto these tiles or, if using thicker tiles say 8mm/10mm use the thin glass tiles over the thicker ones( as in stick onto the thicker tiles with silicone)
its a dilemma as they are at the bottom of the wall would need bedding out and also they're not as long as the main wall tile.
Your thoughts gents
Thanks again
Two questions.
Your thoughts gents
Thanks again
