Discuss Wires care out of 3 way switch Electrical Advice in the Electrical Advice area at TilersForums.com.
Wires care out of 3 way switch Discussion ThreadWires care out of 3 way switch Electrical Advice
Hi, looking for advice on wiring on a 3 switch light One turns light on outside front door, second one for light in bottom hall and third is for light in hall at top of the stairway.
Before decorating the switch was slackened off for painting around. Unfortunately a brown live wire and a yellow wire with a red sleeve have come out of the terminals as switch came out of casing.
I believe the white wire is for the outside litght.
The top terminals read Common - way 1 - way 2 - Common
Bottom terminal reads Way 1 - way 2 - Common - way 1 - way
If anyone can suggest which terminal they have come out off I would be very
[ElectriciansForums.net] Wires care out of 3 way switch
Wires care out of 3 way switch for the original thread on Electricians Forums
Reply to Wires care out of 3 way switch Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
