Discuss Wiring underfloor heating with 3 manifolds Electrical Advice in the Electrical Advice area at TilersForums.com.
Wiring underfloor heating with 3 manifolds Discussion ThreadWiring underfloor heating with 3 manifolds Electrical Advice
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but getting slightly confused.
Do I need to take a fused spur to each individual manifold to power the pump or can this be done via the three cores back to the wiring centre.
I usually run 3 three cores back from the manifold to allow for the Live- Neutral and Earth. Boiler return and the feed to the pump.
Am i right in doing this? More concerned the 3 pumps will overload the boiler fused spur which is the traditional way we wire underfloor heating it is fed via the boiler spur.
Client has also said they want to use nest, I was planning on running 3 core to each room/zone but I’m googling and seem to be wireless? Does this connection work wirelessly when you say have 20 zones across the house?
Any advice id be grateful!
Wiring underfloor heating with 3 manifolds for the original thread on Electricians Forums
Reply to Wiring underfloor heating with 3 manifolds Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
