Discuss Worx Sonicrafter 250W oscillating in the UK Tiling Forum area at TilersForums.com.
K
karlm98
i have owned a fein and they are awesome, if you intend to do loads of regrouts then go with the fein if you are using to trim cornice, skirts n the like then go with the worx i have one and it works fine does the job well gets a bit hot tho..but at £79 with a yr guarantee you cant go wrong, i also used the Rockwell sonicrafter (made in Mexico) same as worx but dif color and no speed adjuster..oh and no case.
i would stay away from cordless unless you only cut small amounts of wood..not good for regrout or removing adhesive..or anything that requires the machine to be turned on for longer than 10 mins
Reply to Worx Sonicrafter 250W oscillating in the UK Tiling Forum area at TilersForums.com
Hello, first post, asking about career change and possible entry route into the industry. I know...
  • Sticky
Good morning all, I havent been in the business of tiling long. With that being said as someone...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Tags
usa
