As Jerry says above, you need a method statement, to make sure you’re covered.
I’m sure you’ll find tho that Mapei recommenced Kerabond T & Isolastic
Ultra also have a spec for it.
[automerge]1573905856[/automerge]
Priming is the most important part, as mentioned.
Personally tho, it’s not something I would touch with that spec.
there is a 6mm board supplied by WundaTrade I think, to overboard it, but, and get this, their spec is to loose lay it. 🙈
I’d want it mechanically fixed before I covered it.
Combination of cement and aluminium can create hydrogen gas, Aluminium powder is added to cement grout in industrial situation to heavy machinery platforms.
They sit the equipment on the slab with holes for the legs, they then fill with cement grout and aluminium dust, this makes the cement expand and firmly fix the legs in the slab.
A byproduct of this process is hydrogen gas.
This as far as I can tell, weakens the bond.
Those are the pitfalls from my pint of view, Mapei and Ultra are the only two companies I’m aware of that’ll spec these systems
