Discuss Wunda EPS 400 and 10MM 900x900 Porcelain...? in the America Tile Forum / Advice Board area at TilersForums.com.
Hello friends.
I am looking for a bit of advice, you would be so kind.
I have been a long time lurker on here, but as a DIY;er to tiles.
We are having an extension built, and we are at the heating and flooring stages, which brings me back here with some questions. I find myself fighting with bloody adverts!!! what an awful setup that is. ha.
I have done a search and i can find others have asked similar questions but with no decisive conclusion, only opinions.
Extension is made up of solid concrete subfloor to existing, solid concrete slab to extension BUT topped up with 2400x1200 cement boards on solid cement beds with fixings into the slab (Builders cocked up floor heights).
We are going to be heating with wet UFH Using the Wunda Floor EPS 400 overlay system.
Wunda tech clearly states that tiles can be laid direct to the boards with no need for a screed, latex or ditra mat.
Has anyone got any first-hand experience? - I am supplying the tiles and gear to the tiler but given the way my extension has gone with every single trade (Bar the sparks) my builder has got in have been atrocious, i just want to try to be one step ahead.
Builder says they have done a load of these installs and he knows what he is doing.... he is going to install to the Wunda manual... At the end of the day, if there are issues he will be obliged to correct them but i would rather not be going down that road and have it done right from the off.
area is 66M2
If you use Mapei Kerabond T with the Isolastic additive, which effectively makes the adhesive and S2 rather than an S1, you can bond tiles directly to the Wundatherm heating boards. Which we have done a couple of times and has been fine, although the 2 part adhesive isn’t nice to work with and stays green for at least 24hours so tiles cannot be walked for ages which is no good for a tiler wanting to get his floor finished!
My preferred method is 5mm of Renovation Screed over the Wundatherm, Ditra then usual S1 rapid set to bond the porcelain
Reply to Wunda EPS 400 and 10MM 900x900 Porcelain...? in the America Tile Forum / Advice Board area at TilersForums.com
Hi all, I will soon be installing the Wunda EPS 400 UFH boards in my own kitchen, approx 50m2...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi I have ordered the Wunda Rapid Response underfloor heating for my kitchen. We were going...
Hello I’m in Hampton SW London and have a floor problem. Wunda UFH water heating was installed...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
USA Tile Forum Popular
America Tile Advice Trending
Stockport
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
