Discuss Herringbone walls ! The definitive answer? in the Canada Tile Advice area at TilersForums.com.
macten
1,158
Nottingham
I've committed to my first 450 herringbone job - will be 3 walls of a shower enclosure with little 2x6 inch tiles.
Lots of advice out there tells you to find the midpoint of the wall and keep the tile points to this plumb line:
From all the google images of jobs where this has been done I noticed that it gives unequal cuts at the sides which I don't want.
After searching for ages I found this gem of a post:
Dont start with tile points on centre line or you'll get different size cuts either side
Theres 2 ways set out herringbone on a 45
First is to draw a line down the centre of a tile at 45 degree's and line that up on your centre line. Cuts will be equal sizes but opposite way around.
Second way to get the cuts the same way so they are like wings ( best way imo) is a bit more complicated to explain easy to show. Set two tiles herringboned and measure the distance between the points of each tiles but parallel. Then quater it and measure that distance off your centre line and thats you new line to start from off the points. If that makes sense
For example I use alot of 3x9 inch parquet tiles so id be starting 26mm off my centre line to get equal cuts on each side going the same way
So I'm just after some clarification that I've got this right in my head:
If @Spacey360 or any other guru can confirm that's right then please post!!
Lairdy1
Essex
Not at all albert.was gonna wait till i was at work so i could take a few pics to explain it.once you know how its done,its so simple.works for any size tile also.plus your cuts are the same direction so you get a pair of wings.try and post an explanation when im home from work
Is it a secret
macten
1,158
Nottingham
It's already explained at the beginning of the thread mate
Dan
Admin
Staff member
5,039
1,323
Staffordshire, UK
There’s a way to centre herringbone properly. There is a thread about it on here, I’ll see if I can find it rather than trying to explain it all again lol.
[automerge]1570395365[/automerge]
@Dan why won’t my search bar let me type anything into it 🧐
It's working on mine mate.
You got an ad-blocker running?
Can anybody else confirm the search bar is working, and threads are coming up?
Seems alright to me. :)
Dumbo
I now know what to do ,i centred the wall and left was ok but right was nearly a ten mm cut ,there is a calculation ,better to start from one corner sometimes
No calc just understanding what the middle of a herringbone layout is . You probably put one of your tile corners on the centre line whereas you should put the middle of the end of the tile on the centre line
Hi all,
Following this with interest. Please see sketch( sorry for the blue peter offering, technology not my strong point).
I was taught to setout and start herringbone like figure 1. ( it wasn’t a full wall mind, it was a small panel of a four panelled display piece.)
Is it best to setout start as in figure 2?
[automerge]1570432613[/automerge]
Hi all,
Sorry it’s upside down
Re-clad the sill and side reveal of alcove to give me nicer cuts.
Toyed with the idea of building out the right-hand side reveal to totally equalise it all, but I've already shrunk it down and that would have meant losing a really big chunk of it.
Success with the most worrying part - going either side of alcove and meeting up again above it.
Did you pull out any 45° lines on the wall prior to laying the herringbone or just 90's? Thanks👍
Reply to Herringbone walls ! The definitive answer? in the Canada Tile Advice area at TilersForums.com
