Discuss Kitchen tiling: Doing corners with patterned tiles (square) in the DIY Tiling Forum area at TilersForums.com.
UK
Hi All,
I'm about to start my first tiling job (at home) and after thinking about steps have a few questions regarding corners (inner corner(s).
I have 5 msq area to cover, and my tiles are square, each box of tiles contains 5 different patterns, below is an image of the patterned tiles.
Q1: Should I start from the middle of the wall and go out to edges? This might end up with half a tile when it meets the corner, should I put a complete tile on the other side of the corner, or go for another half which would visually look like a whole tile going round the corner?
My thought is if I follow the rule of going from the middle on all walls, I could end up with strips meeting at the corner and not looking like it forms a whole tile as it goes round the corner, but visually this might not even matter? But im guessing in the world of tiling it defiantly does.
My other thought was maybe its better to start at the beginning of one wall with a complete tile and follow it all the way round the 3 walls, in this case I would get a complete tile look all the way around.
Q2: Because there are multiple patterned tiles, I would assume its a must to pattern match the tile in corners? If I go for working from middle out and end up with half a tile at the corner, the other half tile that connects to it on the other wall should match the same pattern.
Apologies for the basic questions, I have looked on youtube and forums, with no luck on my pattern issue in corners.
Thanks for any direction/advice on the above.
Blunt Tool
........and of course line up with the centre of the Hob too!
I’m not suggesting for one second that not wrapping is the way to go or indeed that wrapping is the way to go. I’m simply suggesting that it’s not a black and white argument. Sometimes you need to have an open mind. If you don’t then you become a Dinosaur.
Time's Ran Out
FD199145-1764-4FBF-8B40-25C8A5F1DCA1.png @Andy Allen - I know exactly what random means and those are not ‘random’ - without forethought or attention .
But that’s not the issue - those corners defy logic - to turn out work like that is akin to DIY.
Over 4-5 tiles on a splash back your customers can hide it as with the bottle of wine. But show us your fully tiled bathroom walls with this careless setting out.
Boggs
1,118
Uk
View attachment 104833 @Andy Allen - I know exactly what random means and those are not ‘random’ - without forethought or attention .
So how would you set it out then John?
4 inch tiles, that wall being the main focal point as it’s part of the range cooker over mantle.
The cuts you see are over half a tile, the other tiles are full tiles as the mantle was built to accommodate them and the grout joints.
Andy Allen
1,318
Gloucester
Sorry john, but I'm going to have to disagree with you on this.
And as there is no ' god of tiling ' hand book, stating exactly how this should be done, then it's all just your opinion.
And opinions are like arseholes, everybody's got one ! :)
And my opinion is, I don't like it wrapped round, I prefer to see it random, on this particular tile.
Time's Ran Out
@Andy Allen - I haven’t and I won’t ‘disagree ‘ with any of your posts as it all about doing it correct and a Tiler should know this. The others aren’t worth the effort.
I’d be embarrassed to show those corners and it’s typical of a pretender to our trade to believe that it’s the correct way of doing it and advising a DIYer to copy it as an acceptable way to set out a project.
I’am still waiting for 1 of you 4 who repeatedly disagree to show your method in a full bathroom setting.
You say it’s not a written rule. I doubt if any of you have done a tiling apprenticeship in which case you’d all know how to set out a room.
If you read the OP opening post he’s telling you the correct way because that’s what he believes should happen - then you get these ‘tilers’ pictures showing him DIY blunders! It’s a pattern tile - you follow the pattern round the corner - no wonder our trade fights to gain credibility.
Q
Qwerty
I quite like the random look, it suits the tile after all. I personally would probably match it. Is it wrong?...no. Would I do it that way in a customer's house?...quite possibly yes depending on the customers wishes. I've been asked to do far far worse!
Just showed Mrs Plan Tec and she prefers the random look. Just showed the cat and he started licking himself.
Horses for courses I say!
Blunt Tool
Cats probably a plumber tho :rolleyes:
One Day
Interesting - strong opinions again!
I've worked with, and seen work from many "prominent" (note the quotation marks) tilers in the industry. Award winners, industry figures etc...
Some of the things they do shocked me, equally though, some of the things I do would likely shock them!
In my opinion, if a customer is truly happy and you get paid, it's a success.
Everything else is just opinion...
widler
1,328
England
Ok , my opinion, not the settee, although that’s a industry changer :)
My opinion is , if it has a pattern you wrap it , or try your best if possible ,I suppose there are always variables which makes it impossible , but if it has a pattern you wrap it.
I’ve done it both ways I think, I’m really a self taught tiler , although I did it in my apprenticeship, it was only site tiling, and it’s nowt like 6x6 tiling now :( I don’t do mosaics, hate em, not done much geo , I’d leave that to the specialists like John who have grown up on it, and if I’m honest, I’ve lost interest in work now and would like to retire abroad with a big boat and villa with a pool ;)
Dan
Admin
Staff member
5,040
1,323
Staffordshire, UK
Reply to Kitchen tiling: Doing corners with patterned tiles (square) in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
