Discuss Shower room large tiles. Where too start in the Tanking and Wetrooms area at TilersForums.com.
Mhen
DIY Tiler
Points
88
Scotland
Hi,
I’m about to start a shower room job. I’m using 1200mm x200mm tiles vertically. So it will only be 2 high each row.
What’s the best way to start. If the tiles were smaller I would use a baton to get my level but wiith only 2 high, not sure the best way to start. Should I use a baton and put the top tile on first or should I try and get a level at floor level ( allowing for floor tiles) and do two at a time?
Any help would be appropriated
Dave
Staff member
Subscribed
Points
1,000,000
Co.Durham
Hi , run a level Datum line around the perimeter of your room, central ffrom floor to ceiling , then cut the first row to this datum line if that makes sense .. then continue with second row .
J Sid
Tile the floor first and if the same tile run the cut from the floor up the wall as if the wall is an extension of the floor
Mhen
DIY Tiler
Points
88
Scotland
that looks good but we are using different tiles and different size so wouldnt work. thanks for replying.
[automerge]1569932682[/automerge]
Thanks for the reply.
Yes i know what you mean. Will give that method a go i think. saves me trying to get a level baton 15mm off the floor. Cheers
Dumbo
Those tiles are similar to yours . They have been fixed with a random bond that is why they look different to yours. Your tiles could be fixed in the same manner.
J Sid
Lay a the floor first and level. Fix tiles to the wall, full tile of floor (pretend it's a batton).
If your ceiling is 2400 high its 2 full tiles, if less you will need to cut top tiles to ceiling line
Points
108
bournemouth
Hi,
Hi,
how i use a laser level to ping a line round,, if you dont have access to one, use a level and draw a line all the way round, if the floor is tiled after wall then you dont need to be so accurate with cuts, with in a few mm as floor will cover, hope this helps a little
Reply to Shower room large tiles. Where too start in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
