Discuss Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com.
Status
Not open for further replies.
Q
Qwerty
A 17th Century cottage in sleepy Dorset undergoing a kitchen re-vamp where they have knocked through an old wall into a hidden room (had been blocked off for close to a century!). Called in to sort the slate floor. The original Chinese slate floor was fitted around 10 years ago (some of it over lino floor ). Had difficulty sourcing chinese multicolour slate to exactly match the existing, but got it pretty close in the end. Returning next month once builders & sparkys finished to clean off old tiles and re-seal. New screed poured so that was alright but the old floor was bad........really bad! (anti-fracture membrane under tiles due to cracks & joins)
Pics a bit disjointed as uploading from my phone....sorry!
Nothing special Im afraid, but time consuming and bang on all the same
charlie1
Currently tiling the bar area of an 8 million quid mansion in gleneagles. Anyway, I have lots of work to do in this house but though id share these pics as it was quite unusual problem i had to overcome, the inner cuts to the bar where no problem using templates but to do the outer cuts, i had to make a jig woth wood and some wheels to ensure it workes smooth (will post pic) then i cut with angle grinder then profiled with diamond pad.
MakenaTile
you make me glad I use ring saws! curved cuts are easy- new trick I figured out when trying to fit tricky pieces or notch around something- put one or many rows of clear packing tape over shape/area cutting into- draw cut lines needed on it- pull off and stick on piece getting cut- instant cut pattern transfer. (cut with tape on tile)
For job above- you'd run a few rows over the first cut line on 1 or more tiles at a time- trace cut with fine tip sharpie -measure and mark on the tile cutting in- where the cut enters and exist each particular tile- lift tape and line up ends to those marks- shape is instantly and precisely transferred.
maybe you all knew this already...
AliGage
Subscribed
Nice Tony!
Here's a few pictures of my current project. Very small bathroom. A traditional style install, crackle glaze tiles, will be a nice cast iron radiator going in next week sometime as well.
View attachment 46519 View attachment 46520 View attachment 46521 View attachment 46522
I've just completed this bathroom today after getting the floor done and fitted the cast iron radiator. You can views these on my face book page (link in my signature) or on my website Kitchen and Bathrooms fitted in Peterborough
Status
Reply to Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com
  • Locked
I spend some time in doorways. TJ's Doorway Mosaics for McKenzie Shop Front
  • Sticky
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread...
Join The Tile Association and Get Noticed Some time ago joining The Tile Association may have...
Morning all. Dan asked me to post up a thread about our training centre which he can then use...
