Discuss Priming with Bond It SBR in the DIY Tiling Forum area at TilersForums.com.
UK
Hi, super basic question,
Okay to prime standard multifinish surface and left to dry the day before tiler comes, with Bond It SBR Admixture 1:1 with water?
SBR Admixture A styrene butadiene copolymer latex, which increases flexibility of cement screeds and mortars and improves water and chemical resistance and durability. - bond-it.co.uk/builders-complete-range/sbr-admixture
Thanks!
UK
4 parts water to 1 primer. I find sbr can skin and peel. You want it to soak in and create a barrier when using a cement based adhesive. Do you know what adhesive your tiler is using ?
Cheers, ready mixed Mapei Buildfix Wall Tile adhesive tub.
Tried to link to screwfix!
Dave
Subscribed
1,000,000
Co.Durham
That is a dispersion adhesive and needs a porous background for the adhesive to key too. It holds to the capillaries in the surface. If you seal it then it can prevent a good adherence and drying times will take ages as it dries by dispersion into the substrate and the tile biscuit.
Reply to Priming with Bond It SBR in the DIY Tiling Forum area at TilersForums.com
