Discuss Fugenboy silicon tool in the UK Tiling Forum area at TilersForums.com.
peckers
I normally use my finger and soapy water for Silicon however I was asked to use a fugenboy on my last job! I had never seen the fugenboy tool before, I have tried plenty off other so called silicon tools over the years and have never got on with them and have always returned to using the finger.
Well i am that impressed with this tool that I thought i would share it with you! It is so good at its job I was amazed! I highly reccomend this tool it leaves such a crisp clear even silicon line.:thumbsup: I used it dry and with in 2 mins i was flying around the Silicon it is so easy to use.
Fugenboy 3 Piece Kit - Silicon Smoothening Tools - AB Sealants Ltd
Gazebo
I've never used one, but open to try it.
How do you keep the bead neat when the tool crosses grout joints, when siliconing a vertical corner , for example. does the tool not go in to these joints a bit????
Hi Tommy
Yes the tool does pop in and out of the grout joint so you have to be careful and i tip or lean mine forward over a grout joint to help rectify this. to be honest on mosaics the tools aren't as useful as on large format tiles.
Reply to Fugenboy silicon tool in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
