Discuss How do I clean up my travertine tiles? in the UK Tiling Forum area at TilersForums.com.
H
Hoppy
Hi,
My travertine floor was laid 3 years ago. The company that did it did a great job but its starting to look a bit worn now and in need of a bit TLC.
Can anyone help me out with what products I need.
Do I need to impregnate it again?
Do I need to use a proper tile cleaner before I put a sealer/impregnator on top? How many coats
I have bought Mastice per marmi to fill in holes that have appeared-I am assuming this is the right stuff to use? How do I use it?
Any replies greatly appreciated.
Cheers
Wayne
forgot to say it was treated with Lithofin protective impregnator when it was laid.
E
enduro
Hi,
Cheers
Wayne
What cleaning product have you been cleaning the floor with?
E
enduro
OK, the reason your floor looks dirty is the soap not being cleaned of the floor properly and leaving a sticky residue that attracts the dirt.
I would use Aqua mix Heavy duty Tile and Grout cleaner, i would apply this to the floor and use a rotary scrubber and let it dwell on the floor for 5-10 Min's and then re-scrub and then use a wet vac to remove dirty solution, then rinse the floor with just water to remove all of the cleaner.
This is the best way to bring it back to how it should be, to do it by hand would be hard work but if its only a small area it could be done.
As for using mastice per marmi to fill the holes this is not a good idea for a diyer, this is a professional product, as its a resin once applied to the holes it would need diamond polishing to get the correct finish so i wouldnt use it, just use grout.
As for sealing just do a test by putting a teaspoon full of water onto the stone, if it sits on the stone then you will not need to apply a sealer, if it absorbs into the stone you will need to apply some more sealer.
What area are you from, could be easier to get someone in to clean and advice on a maintenance program for you. :thumbsup:
Terry Cottar
Hi,
Cheers
Wayne
Great advice from enduro most problems arise like this due to incorrect cleaning methods for example hoovering or sweeping with a brush. the floor should be mopped with a large flat anti static dry mop to get rid of the dust and grit and then mopped with a damp mop using a ph neutral cleaner
tel
Reply to How do I clean up my travertine tiles? in the UK Tiling Forum area at TilersForums.com
Hello everyone. My building had bricking work done on the outside and it seems in the process...
Hi ! I’m a homeowner without any tiles related knowledge. So recently i use this hard chemical...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
I recently had 20mm porcelain tiles laid outside on a new patio. I did notice the tile...
Tilers Forums on FB
