Currently reading:
Tile trim for cement board
Discuss Tile trim for cement board in the Australia Tiling Forum area at TilersForums.com.
mhuk
Nothing has been plonked anywhere, but when it is it'll be screwed to the wall . The "why" is that the wall in the intended shower cubicle is out of true so I plan to line it with aquapanel and the bath is on the same wall - if I don't continue the run of aquapanel the "ledge" will be vertical in line with the shower door.
I'm happy to have a ledge, my question is how this is normally dealt with (other than tiling up to the ceiling)?
2020 Tiler
I'm tiling (9mm) over cement board (12.5mm) around a bath and the board/ tiling will be 1200mm high, so the top will have a "bare edge". What tile trim is recommended to cover the cement board/ tile edge, or should I use something else?
Thanks :smilewinkgrin:
What did you use to edge this (appreciate a while has passed :) ) ? I’m planning the same project and interested to know how you edged it .
WharncliffeSteve
I’ve got the same question but for a different project. I’ve got what is a strip of ‘feature wall’ behind a wood burner & want to use 12mm cement board & 8.5mm tiles with skirting running up to it at the bottom so I thought padding it out with the backer boards would look neater at the bottom where the skirting is, rather than having tiles set back from the skirting, but I can’t really find a trim (preferably black) suitable. Any of you experts got any suggestions please?
Many thanks
Reply to Tile trim for cement board in the Australia Tiling Forum area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Sticky
