When do I use a Decoupling Membrane??
Hi all :thumbsup:
Having never used this product I just want to get things straight.
1. I've just been out to 2 quotes and both of them are using natural stone onto concrete screed. One has piped heating under the screed and the other hasn't. Is it best to quote membrane for both of these jobs as they are both natural stone or just the one with the heating or none of them?
2. Is it necessary to use the membrane when laying natural stone tiles on an upper level onto 9mm ply using fastflex?
3. Is it necessary to use the membrane when laying natural stone tiles on an upper level onto 18mm ply using spf addy?
4. Is it necessary to use the membrane when laying ceramic/porcelain on an upper level onto 9mm ply using fastflex?
5. Is it necessary to use the membrane when laying ceramic/porcelain on an upper level onto 18mm ply using spf addy?
Cheers Ross :thumbsup:
Uncoupling membranes :
How they work
put one hand flat on a desk sit an egg on it ..... slide the hand away...egg smashes right........
Now put 2 hands flat on top of each other on the desk and get an egg put on top .....slide the bottom hand away..............egg is safe
Thats how it works uncoupling membrane 2 hands = 2 layers with the tiles on top, when the floor moves the bottom layer moves while the top layer keeps your tiles safe.
Now this only aplies to lateral movement thats movement accross the surface not vertical movement. eg the floor expands or contracts.
Therefore if you have any doubt that the floor is going to move lateraly you use an uncoupling membrane especialy with stone
Heated floors expand and contract
Wood floors expand and contract
New screeds expand an contract.
tiler
How they work
tiler
Great Post:hurray::hurray::hurray: What a brilliant explanation:thumbsup:
Kev
How they work
This pdf will help you out Durabase Ci uncoupling matting
tiler
Perfectly explained. Thx Mate :thumbsup:
i swopped from schluler to dural as i am a west brom fan and the schluter stuff is in a very nasty wolves colour
very interesting article wet dec, how about a 3 month old screed with 15 mm ply over board. The conservatory company were meant to tile but had no time, said it was all ready to tile , just prime and start tiling.
Whats holding the ply to the floor and 15mm ply is'nt even made:huh2:
sorry its 12 mm, i think, and it looks like they have just screwed it into screed. dont look pretty. dont even know why they bothered to be fair. if they had done a decent enough screed why would you ply?
Well unless its a heated screed you shouldnt need durabase ci as long as the screed has had time to dry properly. If I were you I would lift the ply and start from the concrete yourself. All very well tiling over their ply but if it pops then it becomes your problem.
Make youself a chicken shed out of the ply and do the job as you would normally.
Sneaky suspicion there is a reason for the ply tho.....mmmmmmmmmm
tiler
CCTiling,
wetdec,
CCTiling,
wetdec,
