Cleaning stains from grey porcelain floor tiles
Sarah
Be careful with MN Builders Clean just test a small area first to see if it works. Read the directions thoroughly prior to using. Make sure you wear good quality gloves and that the room is ventilated as the acid in MN is almost odourless. Start by Pouring a little on the floor in the worst affected area and try a test area first. If it works fine then carry on. If it doesn't post back and we will help you further.
tel
I would use Aqua Mix Phosphoric Acid cleaner for this problem.
1. Allow newly grouted installations to cure for a minimum of 10 days.
2. Always test a small area first to insure satisfactory results.
3. Sweep or vacuum the area.
4. Pre-wet surface with water.
5. Mix 1 part cleaner to 5 parts water.
6. Apply solution onto a manageable area of up to 1 m2, do not allow solution to dry.
7. Allow to dwell 1-2 minutes.
8. Agitate with a scrub brush or white nylon pad.
9. Mop up dirty solution.
10. Rinse thoroughly with clean water agitating with a scrub brush to ensure removal of cleaning agents and acid.
11. Repeat procedure if necessary.
www.tradetiler.com sells it
Andrew
Great Advice as usual! The only issue I have is that if the grout is modified the polymers will have to be broken down first to allow the Phos Acid to get at the cementitious properties would you not agree?
tel
Andrew
tel
Aqua Mix Sealer & Coating Remover may be needed first, to break down the polymers in the grout. :thumbsup:
Sarah
tel
THat i agree on..builders clean isn't one of my favs... a bit harsh..
Best Floor Tiles
sarah_louise_b,
DHTiling,
sarah_louise_b,
DHTiling,
