Impey Tilesafe Membrane
Andy, Phil-thanks.
I don't know of anything like that here for waterproofing.
There are some well-known "peel and stick" products for floors, used for crack suppression. Some of them can be a PITA, I can imagine trying to get it on the walls would be, as well.
Rob, when it first came out over here I got a hotel to do where it was specified in the showers - all the adhesive companies shied away from it, but PCI had the strength of their convictions and guaranteed their single part flexible cementitious product:thumbsup:
Stuck to it a treat:thumbsup:
It's not the best stuff to work with as tanking though, but does the job:thumbsup:
Hi andy-p
I have an aqua-dec tray fitted(Porcelenosa supplied tray) and my tiler is going to complete job next week but is very unsure of imperband and butech tile to wood adhesive supplied by porcelenosa.
What adhesive would u recommend and is there preformed jointing tape and corners for the job?
Also does he need to use a primer before puting adhesive on
Thought it would but imperband was sent and butech tile to wood mixable adhesive and as I say tiler hasnt done this sort of floor before
Just did a quick google and Butech is from the Dunlop/Bal camp. Doesn't get great reviews. (2nd link says Pants Adhesive!) Get yourself to a tile shop and get one of the top brands, Mapei spf would be my choice
I did read that "Pants" review but I think that was for there ready mix tubs and not the 2 part adhesive.
Do u need to prime/bond the tray surface before applying adhesive and also is the order for tanking
Floor then joints then wall?
Cheers
Jim .. You dont need to prime the tray but prime the walls , tank walls first with the imperband dont use the 2 part but a single part flexi , then tank the floor using the 2 part , Porcelanosa dont usually supply the corner joint tape so i usually cut say 200mm strips off the imperband and use that , any more info needed just ask...
i have used impey tilesafe membrane a couple of times last few months.
no doubt im sure that it does the job, but it can cause heightflatness background issues in my view dependent on what tiles are used .
this overlaying of membrane is logical but if you are going to use glass mosaics you end up having to re skim with adhesive to get a smooth flat background.
this takes alot of time to get perfectlty flat .
there are many tanking kits that do not need such a big build up and overlap and they seem to be alot less expensive as well.
We have just used this product on 5 wet rooms in a new build.
We used the preformed corners and brought the tile safe into these. Its on a screeded floor to a Gerbrit Gully system.
We experiensed that the mebrane shrank and pulled the corners away from the wall.Also where the membrane has shrunk it pulled away from the profile within the screed for the slop running along side the horizontal level edge.
Major problem for us. Has any one else experienced this happening?
We have got the manufacture sending a rep out, but as we all know they allways blame some one else rather than say its a product fault.
What other system can anyone recomend? If this product (which was supplied by the client) is found to be at fault.
In the past I have used a matting style material that is laid onto a tile adhesive then smoothed out. It seemed to be a lot less thick and the build up in the corners with the tile safe was around 4mm. Not sure this would bond as well though to the gebrit gully.
Any advise would be greatfully recieved.
regards
Impey UK,
Dan,
Impey UK,
Dan,
