mosaic mesh
Well dp, i aint a real tiler then, (well i am a plasterer 😉 ), i used on a full feature wall, worked a treat, stopped them slipping as well. I tip my hat to proper tilers , god save the queen 😉 🙂 🙂 🙂
Ive used the mesh on part of a wall, cant remember what make it was. I made sure some addy came through the mesh to hold the mosaic to make sure they stayed attached even though the glue on the mesh was dead strong. And made sure the grout was well worked in. I found the mesh a pig to trim.
missyT
The Adhesive stops the slipping if you mix correctly ,and use a good quality adhesive :80: I'am a spread too :thumbsup:
I just see this, what are them plastic things for ? ?? i first showed an article a long time ago about this sort of thing and the water based glue they were fixed to the mesh that was to dense to allow contact with between tile surface and adhesive here http://www.infotile.com/pdfFile/advicetopic/48201031834.pdf take a look , a real tiler don't need plastic things like them for anything !!.
That was a read and a half, that wholesaler is like the Erin Brockovich of the tiling world!
mosaic mesh
The D,
NZ_Tiler,
The D,
NZ_Tiler,
