Overboarding with Ply - WPB and BS standards
SteveyJ
Hi all
Quick question about overbarding with WPB, I have been buying my WPB ply form a timber yard for ages now and the prices keep getting higher and higher etc and now the stuff there selling me isn't even stamped, and isn't as good quality as it used to be so guess not from a quality Norweigen supplier. Looking and asking about the spec they say it is WPB as come with the standard of EN-636-2 which mean can be applied in humid environment and wet if treated on edges etc.
So it got me thinking if this isn't stamped quality ply anymore what is else where, so it got me thinking what is the difference between Spruce ply WPB and and hardwood ply.
This are examples of the Spruce:
http://www.travisperkins.co.uk/p/22mm-sprucefloor-wbp-2400-x-600-x-22mm-pefc/886904/3893617
http://www.wickes.co.uk/Wickes-Structural-Spruce-Plywood-12x1220x2440mm/p/164537
And example of the hardwood:
http://www.wickes.co.uk/Wickes-Non-Structural-Hardwood-Plywood-12x1220x2440mm/p/110116
As you can see all have exactly the same reference code for WPB (EN636-2), so wondered on peoples thoughts. I know about cement based boards, no more ply etc, but wondered what the difference is between the types with regards to our job of tiling on to it, and being able to take adhesive, ditra mat etc. I know that the spruce can be used as shuttering as the wickes advert states but it is not purely shuttering ply and is the same as the spruce from Travis.
Thanks Steve
For me the plywood is there to provide strength and stability to the substrate!
With Ditra, Hardi and Wedi boards there is no reason to want to tile direct to any plywood!!
Hi thanks for all the replies. I have never used Hardi / no more ply, but have never had a reason to to be honest, as not had issues with ply myself. I find ply a good option as if there are T&G boards installed and been repaired previously and/or at different heights, damage, level etc this is no good to go onto with Hardi, so ply gets laid. (Different option if chipboard is the substrate). To be honest I don't like the idea of adhesive on T&G boards directly either for Hardi due to other adhesive or varnish on them over the years, and if you remove the whole floor your going to have to lay 22or maybe 18mm poly anyway, so it goes back to my question about the type of ply.
Timeless John, I agree with what your saying but if a floor needs extra strength added to it, then I would over-ply, and then lay ditra on top using af100. So my question is what should board would be best to get according to the types available?
I've lost the question over this post. Are you asking what the difference is between spruce and hardwood ply??
Spruce - generally quick growing softwood is used (cheaper option)
Hardwood - dense wood grown for a lot longer therefore generally more expensive.
The standard that qualifies ply as WBP is nothing to do with the type of wood used, its the quality and bond of the glue used to layer the sheet. Its this standard that determines if the lamination of the wood will qualify to be used in damp, humid conditions or areas subject to moisture, steam etc.
All of which is irrelevant in my opinion as water and damp will rot, deteriate and manipulate wood regardless of spruce softwood or old english oak.
Tiling Standards
SteveyJ,
AliGage,
SteveyJ,
AliGage,
