Can someone help before i lose hundreds
Joist's normally have a gap of 14-15inch's, Like I stated previous the ply screwed down and the insulation there's seem to be some tension in the floor and if the battons are loose there's probably bounce on the ply, The heat in pipe's could be causing expansion, All probable causes but no definite outcome IMO
It's a different ball game now that they owe Mike 1600 notes. Another lesson Mike, material costs up front. Good Luck mate
You say he is in the "building" trade well I find this hard to believe as he would know not to buy materials from a d.i.y. store. I believe the materials were substandard and that the floor is suffering from some vertical movement. If you re grout you may find you need to return at a later date to replace cracked or de bonded tiles. I would prob have gave this job a miss. You could have contacted a adhesive company for advice before commencing asking if a 2 part flexible adhesive such as fast flex would be more suitable. If they say no then, pass on the job. Hope this helps as itss my 1st post!
In my opinion they should never have tried to lay a floor over that mess. If they are going to build a floating floor they should do it right. A better alternative in my opinion would have been to constuct the frame of the floor with joists at 400mm centres. This would be laid of=ver a DPM and they would fit insulation board between the joists. The next step would be to sheet out the floor probably with chipboard and then ply over this prior to tiling. Floating floors are not always ideal at the best of times for tiling but, the way described would be best in my opinion.
Another option would be to screed incorporating a DPM.
The kitchen fitting should be entirely different and if your having trouble getting the cash then you need to bite the bullet or take more drastic measures!
why do you think your having difficulty getting payment?
Are the battons fixed to the concrete? and is the ply fixed to the battons, all at 300mm centres?
Hi all thanks for all the input.
Any ways guys what do i do now, they wont answer my calls "apparently there's a letter in the post from them" I've offered to re do the grout, and they still owe my £1600 for the cost of the kitchen i fitted, which i owe Howdens joinery for.
Mike
I smell a rat here.
Make sure you get to fix any issues they raise. You're entitled to by law. You don't want any of this, 'we had to get another tiler in to repair your grout, he charged us £600, here's £1000 for your kitchen'.
If there's a problem with your work, there has to be a site inspection for you both to come an agreement.
Why would you go to the trouble of laying chipboard then over board with ply? Just use decent ply in the first place!
Hi grumps,
the chip board would be the standard way for a floating floor and as the guys chose initialy to lay wood this wood have been fine. As they then later decided to tile the next step would have been to ply over idealy.
Oh fekin it is lol if i don't laugh i'll probably will cry, lol again.
ok then, assuming the worst case senario now, the batons are not secure.
and there's about 1mm to 2mm movement, will flexible grout cure this problem as the tiles are now fixed well.
This is a worst case senario, as i've put down the floor and i know everything is tight.
so what can i do now, only 4 tiles are showing cracking grout around them.
Mike
mikephillips,
tfs,
mikephillips,
tfs,
