Grant Faulks
Hi all,
I'm new to the forum so please forgive any silly questions, I've taken on rather a big DIY job so some expert guidance would be appreciated on occasion.
I recently noticed our tiles cracking
in both our adjacent upstairs bathrooms. After taking these up I found that the original chipboard had been soaking up water, had expanded, rotted and gone mouldy.
After a sizeable quote and insurance excess i decided to tackle as much of the flooring and tiling as I could myself. 🙄
The job has typically ballooned from there, not least because I decided to take the opportunity to completely replace/ upgrade everything, move a toilet, basin and radiator, install a back to wall toilet and create some alcoves in the main bathroom (not done these last two yet).
I'm very careful to take on only what i realistically believe i can handle so after plenty of research and Youtubing I've gutted both rooms, ripped up the chipboard, reinforced the floor, replumbed, added insulation, cut and laid 18mm WBP ply (sealed with SBR under & sides), repaired the walls and am now at the point of laying 6mm hardiebacker.
I'm doing this today hence the urgent question(s), pretty certain I've done everything right but I want to make sure:
Q.1 - Do I use SBR on the ply to prime or bond?
I'm using Mapei Mapeker Rapid-Set for the Hardiebacker, which is ok for ply. It doesn't mention priming ply first and I've read the sealed ply shouldn't be primed on top just sponged with water before spreading adhesive. Is this correct or should I prime the ply with SBR before spreading the adhesive? (I realise it's only intended to fill gaps under the hardie in this instance so hoping not?)
Q.2 - What is the minimum depth of adhesive under Hardiebacker/floor tiles?
The 18mm ply plus 6mm hardie plus 10mm depth ceramic tiles plus adhesive throughout raises the floor height substantially so I'd like to minimise adhesive height where I can.
Q.3 - Do I use SBR to prime/ bond large ceramic tiles to the plasterboard walls?
I understand i should at least prime the walls before tiling which would be 1 part sbr to 3 parts water (like I used on the ply) but as I'm using large 500x300x10mm ceramic tiles I think bonding would be best, particularly as the walls are all dry wall, some partition dry walls with metal C studs which can flex a little, and are pretty patchy/had to be repaired/filled in parts..I'm worried about the flexibility and bonding, the Everbuild SBR instructions for bond mix indicates 1-2 parts fresh cement (mapeker for me) with 1 part SBR which has to spread and tiled on within 20mins/before dry. Should I use sbr to bond? If so is the best way to mix up the addy in one bucket and have a second for pre-bonding with an addy and sbr mix?
If someone can help in the next hour or two/sometime today that would be really appreciated.
Thanks,
GF
Thanks,
GF
