olly330
Hello,
I'm renovating my house which recently purchased, bathroom is currently back to brick as the old pb came off with the tiles.
So we are going to dot dab it and use appropriate pb.
Does this have to be waterproof pb all over the bathroom, or just the shower area? Also, does waterproof pb still need tanking in the shower areas or does the waterproof pb in effect have the tanking built in?
Also, I'm regards to adhesive on the walls. Tiles will be going ono fresh pb, defo will not skim.
However, I am reading conflicting information about whether the wall adhesive has to be flexible or not... I read a lot I discussions and no one seems to mention this.
I know for certain that in wet areas we should use water proof adhesive, but I can't find a clear answer on whether the wall adhesive has to be flexible or not?
Other areas around the bathroom such as toilet cubicle/sink we will use bal green star b100 as we are on a budget and can get it for £10 per 15kg tub, is that ok or should we just go for waterproof adhesive in the whole bathroom to ensure no problems down the line.
