BAL Best way to apply adhesive , floor job
Brody29
I have a 5x5 metre floor to tile with 60x20 porcelain tiles, I am using the levelling type spacers with the wedges for the first time. Is the best way to apply the adhesive with a 10 mm trowel onto floor and also back butter the tiles with same trowel?
Thanks for any advice
So I've been doing it wrong!
To allow the air to escape therefore allowing the notches to compress for a more solid bed. Swirled like spreading patterns cause the air to be trapped and the compression resistance won't allow the tile to fully colapse the notch and in turn prevents a true solid bed.
Thanks for the responses chaps, so the General consensus is, spread the floor with 10mm notched trowel, then also back butter tile with notched side also, and make sure notches of floor and back of tile run in the same direction to allow air to escape for maximum compression?
BAL
Brody29,
kevsalt,
Brody29,
kevsalt,
