Bevelled Metro Tiles..... Trims, edges and window reveals.
What about leaving the biscuit back exposed ?
Painters chalk....
Trouble you get with metros is the middle of the tile is 8mm the top 6mm so an 8mm trims on the top ends up with a horrible lip......personal choice really.....I've done it both ways but hate the lip at the top.
Yeah there's always the difference in thickness between the bevel and cut. I don't think it looks bad. Personally unless it's a rustic tile I think no trim doesn't look right on an edge.
Thanks for your comments.
Spinning the tile around as Drawing A appears not to be recommended.
I did consider not using trim on the edges, but I reckon on the tile edges look unsightly, these days.
I think I'll get some trim, cut a few tiles and mock something up.
Chris
Diagram B is correct .. Also you could reduce the whole tile just after the bevel to achieve the same thickness (8mm) consistent to suit for trim...if that makes sense😉
Thanks. Yes it does make sense. I've considered this as well.
You could Start on the 3/4 of the tile and you get even height on the the trim with both cuts as long as you don't get small cuts in the corners and around the windows
DIY Tiling Forum
Chris Bates,
Dan,
Chris Bates,
Dan,
