How long to wait until tiling onto 75mm screed
If I remember rightly Schluter claim it can be tiled as soon as weight bearing . I stand to be corrected and if I was doing this I would obviously check .
The phrase they like to use is,
'as soon as its mechanically repairable'
Tape the joints for moisture sensitive stone, otherwise not necessary, but certainly doesn't hurt, personally I'd prefer it.
But yes as soon as its load bearing.
To fast track a screed a 'vapour equalisation barrier' must be used i.e.
Ditra 25
Durabase mat
These mats are not for wet ufh obviously, but they still do the same job as above.
Ditra E Heat mat
Variopro ufh mat.
i treat S&C screed beds over UFH the same way as concrete 1 week per inch to dry, so at 75mm i would leave at least three weeks and not force dry it by using the UFH. I prefer to let it dry naturally. Then go with Ditra or durabase for crack suppression.
You can tile on a green screed after 28 days using tilemaster ultimate but that doesn't offer any uncoupling if you want that.
Is green screed flexible enough for the ufh..?
Maybe not on a green screed.
you could probably used ultimate to stick crack mat down then tile with ultimate on top of that. Cheaper than ditra
ashurst,
Geoff Thacker,
ashurst,
Geoff Thacker,
