Norcross pro gym base a game changer
Hmm. Average ambient temperature of 20c. Could be a problem for 50weeks of each year!
Alan, what happens to the moisture if it's blocked in?
I asked all the questions about this on tilers talk and didn't really get any answers. All the tech sheet was on there too.
20oC is considered room temperature and effectively british standard temperature. If it's warmer itll take a bit longer to set if it's warmer it'll not take as long
The moisture is not locked in. It is allowed to release very slowly such that the tile face and grout joints can cope with it without detriment the bond strength
No idea about tiles talk but as the system was only launched on Monday of this week I guess it will take a while for the answers to disseminate.
The system has been thoroughly tested on our screeds at an independent test facility and the test results were really impressive
is there a technical reason that it will only work with their adhesive?
It's been 24degrees for the last three weeks here
It would not be appropriate for me to answer that. We're I to say it can be used with any adhesive it could be seen as undermining an industry ally. If i were to say it can omly be used wuth theirs it could be seen as anti competitive. I will simply say that I am not aware of a technical reason it can only be used with their adhesive but that the usual advice is try not to mix and match systems.
Ajax123,
Ajax123,
Ajax123,
Ajax123,
