Keeping Things Clean with Dried in Powdered Adhesive
Weebisto
Hi all, I am relatively new to tiling professionally but thoroughly enjoying it so forgive me if this seems like a strange request for help. What I am finding when using powdered adhesive is that even when I only mix a small amount at a time because of its limited bucket life I am going through buckets like nobody's business as the remnants are going hard at the bottom and around the sides. The same is happening with my trowel. I know buckets aren't exactly expensive but trowels are and every penny is a prisoner - I can't help but think that I am doing something wrong. Any suggestions from you experienced guys would be appreciated. Ta
Have a bucket of clean water and a sponge handy to clean your tools every now and then. Unless you're using fast set you shouldn't be having trouble washing your buckets out if you're only mixing small amounts.
Use a standard/slow set adhesive, only need to give buckets and trowels a clean once at lunchtime and once at the end of the day. Exactly same spec as an S1 rapidspf it just sets slower 😉
Good tip - thanks a lot
Thanks a lot for that - it has been quick setting adhesive I have been using so will switch products
Unless I specifically need to get onto a floor I'm doing quickly, in which case I'd use a rapid set, I would always use a standard set adhesive and it would be Mapei Adesilex P9. It sticks ceramic, porcelain and stone, a good grab and a pot life of just about all day. It's a good product at a good price so little wastage.
What you have to think about with slow set - in the winter it will take longer to set than in summer, and you have to watch for shrinkage when it dries ( those lips weren’t there when you tiled it)!
Weebisto,
Tommythetiler80,
Weebisto,
Tommythetiler80,
