Silicon for use in a steam room
Gents,
Any idea what the best Silicon would be to use in a steam room?
I need to Silicon the glass U channel areas as they have finally started to go mouldy after 6 years of use. I wish I could remember what the last brand was as it's held up so well but I just can't remember.
Thanks!
I personally use Dow Corning for white or clear and Mapei or Ottoseal for colours.
Do try our sponsor @ISOMAT UK as I understand they also sell sealants
Thanks for your input.
I was considering using the above sealents but am wondering if I may need something that resists more heat. The above sealants can handle temps of up to 150f so I guess I'm just being overly cautious as some specialist silicones can handle temps double that, but cost five times the price.
I tried a product called Muffycid which worked really well and removed the bulk of the mould, but the original Silicon is looking a bit knackered and seems to have worn a bit over the years. I think I'll defo change it to keep things looking tidy and fresh in there.
Domosil S looks good with a high temperature rating.
https://www.isomat.gr/wp-content/uploads/2015/12/e-domosil-s.pdf
Has anyone had any experience in using this as I wondering if it sets of hardish due to it's high mechanical strength?
Have you ever measured the temperature in your steam room as 150 degrees f seems pretty high
I always use Dow 785 Sanitary Silicon in bathrooms and wet rooms and would go with that again. Alternatively, I'd ring them up and ask if there was a better product more suited to steam rooms.
Tanking and Wetrooms
4DoorFist,
ISOMAT UK,
4DoorFist,
ISOMAT UK,
