To Tile or not to Tile... (myself)
Hi all,
So long story short, I have just purchased my first house and I am a avid DIYer. I am looking at installing some "wood effect" porcelain tiles in my downstairs hallway/kitchen/utility room/WC.
I have only previously helped my dad with tiling projects at home and I am wondering if this is a job to big to take on as my first "solo" job? (totalling about 35-40 sqm2)
I have been researching it quite a lot and speaking with my dad a bit and have the confidence to try and do it myself.
is there any tips or tricks / improvements you could give me on my below plan?
1) check floor is level and fix if needed otherwise lay tiles straight onto the dry concrete slab
2) measure the middle line with a chalk line (dry lay and cut some tiles), but start at the kitchen unit edge to make sure the tile is straight to this.
3) mix adhesive and use a trowel at 45° to get the correct thickness. and back butter the tiles as being wood effect they are classed as LFTs.
4) looking to use something like the T-lock levelling system to aid in the achievement of keeping all tiles level to the surrounding tiles.
5) grout when adhesive is fully dry.
other question I have, what grout thickness should I go? 1, 2, or 3 mm? I would like to achieve the most professional finish possible (as all good DIYers) as well as the most realistic to a hardwood floor structure.
Regards,
Josh
I'd want a straight line in the hall. If the kitchen isn't square to that it'll look awful when you come in the front door.
Have you got a floorplan you can post?
Hi pdc,
thank you for taking a interest in my project, please see below for a floor plan from SketchUp all the white flooring will be tile ( kitchen island will be installed after flooring)
Hi Josh and welcome. I am also a DIY person and I will paste below some words of wisdom passed to me recently (he did a half decent job on a big install)
"Yes a lot of planning for sure, 3 criteria mainly, aesthetics, technical and best use of material. You can break many rules in relation to conventional tiling, as regard set out, however, on installations there is virtually no room for compromise.
If installed incorrectly it will fail, not maybe, it will. "
Planning, Flattness, Levelness, Planning, Flat Tiles, line from the front door, primer, I like larger grout gaps. Anyway you will get plenty of good advice.
One question is can the run from the front door run right through in one continuous section ? Will the gaps around the edge of the tiles be all thats needed for movements and expansions etc ?
Hi Adey, thanks for helping me on my first tiling project. Quick question actaully what is the best way to make sure it’s level? I only have like a 1 meter straight edge? Would a longer one be better or is there another solution I could use?
Hey Julian,
thank you and saw few bits of your work on the other threads, looks professional to me! Not sure to be honest and the expansion gap etc? I have the option of taking off the skirting boards and tile “under” them and plane them down the required size nessary. Or attach them before and tile up to with a grout line. Not sure the more professional or preferred way.
Regards,
Josh
I would suggest getting a longer spirit level 1.8m, you can pick up some good quality cheap ones then you can use to find out if there are any high or low spots you need to address before tiling
When tiling mutible rooms you need to get plenty of lines down to get everything as straight as possible from to point of entry, which would be the hall.....and then make sure it squares up with the kitchen,
Then make adjustments to suit...
Not an easy thing to achieve for the first time but good luck..
Hi Adey,
Thanks for the advise with the longer 1.8m spirit level. Does anyone know, if it’s a new build can I get the build/developer to come in and level it as a snag? Or is that down to me to level 100%?
Hi Andy,
Thank you for the heads up I guess I should put a line in each of the smaller rooms and 3/4 in the kitchen?
Regards,
Josh
DIY Tiling Forum
Tags Tags
not tile
Josh Wells,
Dan,
Josh Wells,
Dan,
