Discuss This will be a long tiling job !!! in the Australia Tiling Forum area at TilersForums.com.
Simon Dale
1,108
Maidstone
ZMJULAwoQRigE%qjugxL%w.jpg 9rqb%vNgRSe1TRmdVyMLQA.jpg m7%lGwGVSxKzM2FBF+rLFA.jpg
Did they just buy a bigger telly and Marc blagged the original one?
I wish!
To be honest, I don’t actually recall that incident on the tv niche, however, there was also a further 8-9 pieces it could have happened with, and the factory did admit the batch was faulty.
There was also another job where the same exact scenario occurred recently.
So even tho it’s a fairly rare occurrence, it happens often enough for me to get particular incidents confused with each other.
It’s typically down to bad handling by someone, and my ageing memory. :D
Who pays for the new pieces if they are unusable after a fracture etc?
Apart from how much to value a project at, that’s probably the most difficult question there is to answer.
A few of us have now become resolute in the thinking that if there are no spare pieces purchased, we won’t undertake the project, although it’s still not easy to implement.
If you have something like a 3-4 tile chain, theoretically, you break one, you break them all.
Getting one individual piece to match a chain is not the easiest task to undertake as you will appreciate Tom, I am led to believe it is possible though, sometimes.
We always make it perfectly clear that this can happen, it’s thin porcelain after all, it breaks with ease given the right circumstances.
There’s a very clear and specific way of handling and cutting this material, try and take shortcuts, and you jeopardise every piece that you handle.
So in a perfect world the client is responsible for replacing damaged pieces, now whether there is evidence to support the damage occurring before it’s arrival or indeed of it being badly handled before we touch it, that is another thing.
The client would have to take that up with a third party, usually supported with our input.
On a personal level, if I blatantly mishandle or abuse a piece, I feel it’s my responsibility to replace it, and I have done in the past.
That said, most projects are sufficiently large enough to be able to reuse most damaged pieces elsewhere, and it not cause an issue, but not always.
I feel that as long as you have the clients trust, as an installer, it’s rare you would have to dip in to your own pocket, if you’re competent at what you do.
There doesn’t appear to be a cut and dry answer to your question Tom, but one thing is for sure, we try to make damn sure, it’s not us! :)
Katrina, bless her is discovering the best way to mitre as it is a bit of a stretch sometimes. We cut the niche out on the table and it fractured. The more we tried to mitre the more the fracture went. Bit the bullet and cut another 25mm off, problem solved :):)
Just a thought . I don't know if it was possible. But maybe if you had drilled a small hole at the end of the fracture it may of stopped it by dissipating energy around the circle rather than just at one point .
Simon Dale
1,108
Maidstone
Didn't think of that. If it happens again ill give it a try :) JNdB92fkTj+GmjyBjHs1Nw.jpg fullsizeoutput_862.jpeg fullsizeoutput_863.jpeg
Italy
Today was crap in terms of working. Cleaned out room moved all gear into next waited for client for grout choice, which he didn't make ! Moved a big thing upstairs PMPL. So much wobble :eek::eek::D Stuck one on the wall and prepped another with 4 holes cut out. :) As you can see Katrina not amused :D:D:D:D:D:D:D:D:D:D:D View attachment 99249 View attachment 99250
you're ruining the "MY" preferred tiler....:(
Reply to This will be a long tiling job !!! in the Australia Tiling Forum area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses in Stoke On Trent’s Once Thriving Ceramics and...
  • Poll
Have you ever worked for a National Tile Supplier or even just smaller big chain tile suppliers? I'll tell you a funny story about how I got a job with Topps Tiles Newcastle and got top sales...
  • Suggestion
Was a full room custom ensuite install made to measure vanity, bulkhead for the stairs is in bottom drawer of the vanity unit
