Tiling Rates Per Square Meter - How much does tiling cost?
Hope it's alright to ask this. I'm not actually a tiler yet but hoping to get into the trade soon. Can someone explain to me why the differences in prices, I.e 30 per m2 for ceramic but 40 per m2 for natural stone or marble etc? And say 30 m2 for 10mm thick (example thickness) but 35 m2 over 10mm thick? Do these m2 prices include adhesive and grout etc?
This has all got to be based regionally...however I don't think for one minute someones getting away with charging 40-£50pm all day every day, that's going on £200k a year...lets be realistic eh :tearsofjoy:
Based on 10-20m a day, which is being realistic, we must have some millionaires on here then..
As everyone has mentioned above, costs can vary dramatically but a quick price for walls and floors would be £35 per sq meter, £200 day rate which would be for kitchens and geometric patterns. £55 per sq meter for most stone work. All of those costs would be for tiling labour. Preperation would be an additional charge, rough estimate would be just under double.
Usually price the job as a whole and separate out materials ( adhesives/ backer board/ slc/ decoupling / trims / grouts/ silicones/ diamond bits etc and tiles if I’m supplying) with a separate quote for labour at 200 a day unless I’m staying away then it’s + expenses.
If it’s fix only then per m2 depending on type of tile and layout.. 30-40 for ceramics.. 40-50 for larger formats extra for mosaics/ natural stone/ herringbone/ Victorian etc
Jobs with natural stone products simply require more time to lay and finish, all the cuts have to be done on wet cutter , they also need cleaning and sealing . In general thicker material involves more fitting time due to slower cutting process.
£45 sq mtr walls £35 floors if porcelain or ceramic and a reasonable size tile. Anything else would be on a day rate of £175/200 depending on travel time parking etc. Hope it helps
Dan,
Dan,
Dan,
Dan,
