tanking hardibacker joints in shower area
Hi all,
Just seeking advice on wet area joints in hardibacker.
In a "dry" area I would normally fibatape then skim with addy.
Should i still do this and then tanking tape and then tank membrane over all?
Will this be a bit thick at the joints?
Or is it OK to just use tanking tape over joints in the wet area before the liquid membrane?
If anyone can offer an informed opinion on the best practice i would be grateful.
Regards
Neil Davenport
Also dont forget that 12mm Hardie need priming in all instances. not 6mm for some reason. (I believe)
I prime the hell out them anyway . Don't care what is said I don't think it reduces bonding strength significantly if at all.
Tanking and Wetrooms
davenport.neil,
Dumbo,
davenport.neil,
Dumbo,
