Hi everyone,
I'm attempting to tile a new kitchen splashback using cube shape mosaic sheets and all going well, except I'm not sure how best to finish the grouting.
The splashback will not go to the ceiling and there are no wall cupboards.
There's several examples of the same style on this site. Creative Tile Finishing Ideas with Organic Edging - https://mercurymosaics.com/blogs/news/creative-tile-finishing-ideas-with-organic-edging
I was thinking perhaps grout it as normal with a bit extra coming out the top and then using a Dremel round out each bit between the diamonds?.
Also should I run a line of grout along the top of each diamond?
Or Silicon all the exposed edges?
I can't really find anything online about making these king of designs.
Thanks Matthew
i would leave as it is and if your painting above the tiles caulk it rather than Silicon as you cant paint Silicon what colour grout you going to use?
Thanks for replying Ray
Will be using white grout. So I should go up to the top but not over the top tile.
What would be the best way to shape the grout that will be coming up between the two diamonds?
Yes we will be repainting on top
there are a number of caulking tools look on screewfix or some times just your little finger will do the trick.
I’d have thought you should have cut your top tile in half to leave a straight edge, but if it’s on then it’s on, another fix could be to buy some trim ie an L bend and just fix it over the top, so that it gives the appearance that the top is straight. If you wanted it as is ie diamond, just grout the edge of each one or Silicon / caulk right close to the tile and paint to leave a neat finish👍
Grouting half height kitchen splashback
DIY Tiling Forum
magicmat,
Rae,
magicmat,
Rae,
