Advice on using Sigma 3p3m
acaciaguy
Hello all,
I have just bought a Sigma 3P3M Max 100cm tiler cutter to cut some large 330 x 1000 Bernini Marble effect wall tile from tile mountain. They are ceramic and are 9mm thick. I would expect this cutter to eat this up for dinner but I can't get a clean cut. I have a couple of smaller sigmas and haven't had a problem.
This new one I have is a push cutter rather than a pull cutter as I have used on my other sigmas, therefore I think my technique is at fault rather than the cutter.
Any advice on using it / setting it up for those tiles would be very much apprecited.
thank you will do. I have watched a couple of vids on youtube and they differ on whether you push away from the measuring bar or turn the handle around and push towards it. Does it make any difference
We're they sigma videos ,
Look at the sigma book that came with it , they don't show any set up to push against the measuring bar
I agree, I have followed the instruction book and it clearly shows pushing away from the bar. The vids were not made by sigma. I was wondering if I was missing a secret trick by not doing it the other way lol
you have to give little pressure to the handle,
the handle max or klick klock are designed
for engraving and breaking hard tiles.
with ceramics you have to go light.
thank you for this. Could I swap the handle from my other pull sigma? could that help with these ceramic tiles
acaciaguy,
Lazzer,
acaciaguy,
Lazzer,
