Discuss Layout advice, please. Would this look too bad? in the DIY Tiling Forum area at TilersForums.com.
Rosa
268
Leinster
Hi there!
I finally decide to plan the layout from the entry door, with full tiles across the center of the hall and going from there into the adjoining rooms.
With the sitting room works perfect but in the kitchen/dinning room tiles would be too small on one side (as seen in pics).
The grout will be 1.5 in similar color to tiles.
Do you think it will look too bad? Should I rethink the layout?
Thanks a million in advance for your help:blush:
A closure is a shortened tile in amongst full tile to move the layout.
Cut the tile in the doorway under the door, so that the joint runs underneath the line of the door. So when Doris closed it appears to have a large piece either side. Then if need be, shorten the tile going in to the closer to move the layout left to right as we see the photo.
Not quite sure what you mean by your reply tbh Rosa, but if that is your intended layout in the photos, that is not how most of us would set that out.
Personally I would have a centre line down your hallway.
It would give you two equal cuts off the centre line, I would not have two thin cuts down each side of one tile like that, or thro the doorways.
Again it would be centred as near as possible.
The way you have it, you have unacceptable sized cuts everywhere, which are also extremely difficult to do let alone keep in one piece.
Try moving your hallway half a tile over, similarly move everything down half a tile, this will give you much better cuts everywhere.
Ok there may be the odd small cut here and there, but there is always a small compromise to be made.
As it is, as a diy project, it will be a uphill battle all the way.
Spare Tool
Sorry Andy!! I didn't realize it was so late.. an even later in Uk!
Really, you guys are saving me from years and years of annoyance! I truly will pray for you all to win the lottery!!:grinning:
Thanks a million Andy, sincerely appreciated. Tomorrow I will do the measures with what you advice.
That's 'Marc' @3_fall ;)
Sean Kelly
1,068
Ruislip
Rosa, if you are going to give us a Lotto prayer then I will have to give you some tile advice!!
You say 1.5 grout. Do you mean 1.5mm grout line? That's pretty ambitious for a non tiler (sorry, thats an assumption on my part). Also, are the tiles rectified (i.e. all exactly the same size). Lots of large tiles can vary between 1-2mm in overall size. Even a pro tiler would not use such a small grout line. Go for 3mm and use levelling clips.
The above is 600x600 tiles and I used a 3mm grout line. Porcelain over underfloor heating.
Good luck.
p.s. Do I buy my lotto ticket for this Fridays draw? !!
I
Italy
Good luck.
I understood that I will remain an apprentice for life ....;)
Reply to Layout advice, please. Would this look too bad? in the DIY Tiling Forum area at TilersForums.com
Hi, i'm undertaking all of the tiling in our project. I have two different types of 600mm tiles...
First time poster here. For some context, I have a (mostly finished) tiny home with some really...
Hello, i hope someone can give me some advice please. I’m planning on tiling our bathroom walls...
Hello, first post, asking about career change and possible entry route into the industry. I know...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Leinster
DIY Tiling Forum
    Votes: 5 5.1%
    Votes: 8 8.1%
    Votes: 6 6.1%
    Votes: 24 24.2%
    Votes: 14 14.1%
    Votes: 27 27.3%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.2%
    Votes: 18 18.2%
    Votes: 11 11.1%
    Votes: 5 5.1%
    Votes: 3 3.0%
    Votes: 0 0.0%
