Discuss Tiling around windows without trim challenge in the UK Tiling Forum area at TilersForums.com.
andy-p
on the subject of mitred edges on ceramics , i dont like them but its a matter of taste, look at the square edge trim on this , looks better ,safer and protects the tile edge imo.. :thumbsup:
20
258
Guernsey
Hey K613
Take a look at this mitre. It was cut using a small trim saw. No filing. If you measure the length correctly the mitres will come out perfect every time. You can also do it with a mitre block and hacksaw but it takes a little practise to get it right. It is worth the effort. If you cut the mitres with a tile cutter be careful as it can discolour the metal trim due to heat damage.
Also if you are not used to mitring the tiles the trim is a better option.
Reply to Tiling around windows without trim challenge in the UK Tiling Forum area at TilersForums.com
Hi, i'm undertaking all of the tiling in our project. I have two different types of 600mm tiles...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hi, new to forum and after some advice after a professional install. Just had kitchen...
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
