Tiling around windows without trim challenge
if I'm mitring 45 dgs, I always make sure that I've got a millimetre spare from the face, ie my cut might need to be 500mm, I'll make the mitred cut 501mm then I can plane off the 1mm with my wet saw (at 90 dgs) and not have an edge like a cuttlefish.
no i dont think you are mate your local can show you no prob
Cheers for the offer Pete, i appreciate it, but i think i got it from the drawing now.
And i quite like Doug's idea of cutting slightly over then trimming back too.
Cheers guys :thumbsup:
if mrs does not want trim you have to mitre,
and if you are doing it yourself with no time constraints the two "jollys" aka "mitres" can be greater than 45 degrees so cut the tiles without touching the glazed edge then rub the angle greater than 45 without touching the glaze.
it depends on what material you are working with how long it takes but it will work in the end!
WITH
WITHOUT
to be fair Richard, the one without trims doesn't do justice 'cos ot the slithers and brick bond:smilewinkgrin:
the window has not been centred correctly, granted.
and the bottom pick shows a joint that should no be there at the top but hey its mitred well!
but the photo shows the effect!:lol::lol::lol::lol::lol::8:
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
