andy_7
About to use Classi-Seal during a shower tray install for the first time. The instructions cover only up to adding the strip to the tray, and I have some questions for next steps:
- When installing the tray, should I put something behind the blue strip which is in contact with the wall? I've marked this area with an asterisk in picture link below.
- If so, should it be neutral cure silicon, or a sealant/adhesive? I assume it would be firmly pushed in to make a very thin film between the seal and the wall?
- Does tile adhesive go over the blue section of Classi-Seal?
- There is joint tape left over from the tanking kit. Should I put this over the joint between blue part of classi-seal and the wall? Or would this be risky in case of movement?
