Discuss Tiling Abacus Shower Tray in the Tanking and Wetrooms area at TilersForums.com.
I recently installed a new ensuite walk in shower using Abacus Single Fall tray former. I had to build a timber raised platform to sit on the concrete floor (in a flat).
I topped with 18mm chipboard and then bedded it down (sorta) using flexible adhesive. The tray former got bedded down ontop (30mm thick former). I added backerboard to the side of the tray.
The tiler fitted tiles and it looked great for a month until I noticed a slight leak to the baseboard in the same wall on the other side.
It looks like the side ledge to the tray has pulled away from the tray and caused a long line where water can and has seeped through when the shower is on (photo attached).
I think where the tile sits on the former ledge it's levering the side away (as the raised platform has 10mm backer board attached to the side) - I can only assume over time stepping on it the tile has acted as a lever and pulled ledge away.
I have ripped the tray tiles up and plan to refit. I will not use the Baker board on the side this time to reduce chance of pulling away. Whilst re doing it is there anything I should change regarding the platform ie chipboard to hardibacker or ply - what thickness?
I'm a total diy beginner and picked up stuff along the way and YouTube but much to learn. Be kind to me on here hahahahah!
Oli1234514
Get a good tanking kit, jacko do a good one with the primer, tape
internal corners and the solution to paint on. then a good flex
addy Bal or ardex and a good flexie grout again bal or ardex
but before all that make sure the base is realy stable
Would you suggest i remove the chipboard and replace with 18mm ply or hardie? before tanking
Reply to Tiling Abacus Shower Tray in the Tanking and Wetrooms area at TilersForums.com
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
Hey. I doing my first walk-in tiled shower. The shower is 4’x8’. Most of the floor is covered...
Hi. Just thinking about shower trays. Do shower trays with an integrated upstand require sealing...
Stoke-on-Trent
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
