Discuss Plywood for Wetroom subfloor in the Tanking and Wetrooms area at TilersForums.com.
Hello guys,
I'll be converting one of my upstairs bedrooms into an en-suite/wetroom and I want to replace th existing floorboards with plywood but struggling to figure out which type I need. I understand that it should be hardwood plywood which is at least EN 636-2 and EN314-2 Class 2 compliant but then does it need to be structural. Looking through different websites from Wickes to Travis Perkins but they all name the sheets differently and add to the confusion e.g. Wickes say Non-Structural Hardwood Plywood but it does comply with EN 636-2 and EN314-2 Class 2 (what used to be WBP).
Can you please advise what type do you normally buy for wetrooms?
Thank you
Yes, I will be using matting but can you please explain why I can't tile directly onto plywood. That's how people have done it for years and no issues. In my friends two ensuites plywood floor were tiled onto directly few years ago and not a single crack on the grout, tiles or loose tiles etc. The lavatories in the office I work in central London have plywood half walls tiled directly onto. Surely, as it's a commercial building with hundreds of people using them, it wouldn't be allowed if it was unsuitable?
bsc ceramics
Subscribed
yes i know i have done the same for years but for some reason maybe after a few
failed british standards now say you should not tile directly onto any type of wood.
i dont think i ever had one fail but now if one does its because its onto wood,
Thats what they would say.
It includes floors I think the wording is all areas.
Any tiler worth anything will tell you. That's why there's products like tile backer board and ditra and the many others on the market
Funny you mention Ditra, look at this cross section I was given by… Schluter UK.
46
478
Dorset
I think you’ve actually got that the wrong way around!
Because there are products like tile backer etc - they have changed the standards so you are forced to use their expensive products… as you say in previous post, you’ve never had a failure on ply!
but it is british standard
Plywood Walls - BS 5385-1:2018
Direct Tiling to Plywood Walls
Direct fixing of tiles to walls constructed from plywood is not recommended in BS 5385-1: 2018 Clause 6.1.2.7 Other sheets and boards (see also 6.2.3.3) “The use of sheets or boards that are subject to movement from changes in moisture content should be avoided. Plywood and other wood-based sheets or boards should not be used for direct tiling”
Reply to Plywood for Wetroom subfloor in the Tanking and Wetrooms area at TilersForums.com
Hi everyone, I'm having the majority of the ground floor of my house tiled (35m²) and I'm not...
I would like to install slate tile on the hallway and foyer (blue rectangles) of my house...
Hello everyone, I tried to avoid asking this question as I'm sure you're all sick of seeing...
5K
Hi all, (I have tried looking but could not find this subject covered in another thread, if I...
14K
JamesHardie
This is especially for "customers" -anyone who wants to buy or choose their own tiles (whether...
14K
Qwerty
Q
East Sussex
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
    Votes: 9 6.1%
    Votes: 14 9.5%
    Votes: 11 7.4%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 18 12.2%
    Votes: 15 10.1%
    Votes: 7 4.7%
