Discuss Tiling over old pipe in the DIY Tiling Forum area at TilersForums.com.
Old gas fireplace insert getting tiled. Hoping to get an electric stove in there, but tight on space. Plasterer knew this, so didn’t go out the extra cm(ish) and said we can tile over it with a bit thicker adhesive and it should be fine.
Finally got around to tiling and didn’t realise it stuck out so far and protrudes a mm or 2 more than the tile thickness.
Partner just wants to notch out the tile so pipe is still visible as it’s the easiest option but I think it’ll look rubbish. To just tile over it, we’ll end up with a very obvious bulge.
Any thoughts on how we tile this? Can you carve out the back of a tile?
Photos for reference as to what the hell I'm on about…
The question is. Is it live does it have gas in it.
A. No Gas. Just chisel out back of pipe an hit it the pipe flat with a hammer.
B. Yes gas . Is it end of a run if yes chisel out wall and get plumber to cap it push it into wall.
C yes gas . It supplies another area chase out wall , and get plumber to alter pipe work.
The pipe that's there doesn't look in the best of health cement reacts with copper. If the bits in wall aren't protected it may be about to perish anyway.
Options are yours as it's your house , do it properly and safely or bodge it you have to live with.
Reply to Tiling over old pipe in the DIY Tiling Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
Hi all, I'm part re-tiling/plastering a bathroom, which as the pictures show, has masonary to...
I really need some sound advice as I’m well out of my depth. We have a little second home with...
I'm having my kitchen renovated and the tiler came last week and did the floor tiles. They're...
6K
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
United Kingdom
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
DIY Tiling Forum
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
