Discuss Tiling Concern and Need Some Advice. TIA! in the DIY Tiling Forum area at TilersForums.com.
Hey All, So we're in the midst of a project and it's been interesting. Is there a type of edging that can be used to "hide" and/or protect the edges of the tile that are protruding? While some are flush many are not (I realize the walls are uneven and the thin set was not troweled well). And, can/should the gaps be siliconed or backed first then siliconed?
Also, is no ledge acceptable (it was a prefab wall and we thought it would be a small ledge...not NO ledge). We are trying to "salvage" a project. TIA!
AliGage
Subscribed
Very messy.
Difficult to really understand what I'm looking at in the pictures.
Corners, and where tile meets your door trimmings/architrave can be silicone, that should tidy it's up a bit.
The trims used seem either too small for the tile, or they've been pushed against the wall and the tile is left proud. Doubt you can do much about this now, but at the time, if you put a small wedge or packer behind the trim to bring it forward you could if just silicones the gap between tile and wall.
Not sure about the bath tiling. You seem to have lots the bath onto the wall a lot!!
Very messy.
Thanks for the feedback. It's like the further along they went, the "messier" the finish. I think they didn't level the surface and used uneven amounts of thin set (this was a small bathroom gut). I am thinking that maybe we could use a Schluter eck-k type 90 degree corner to hide and protect protruding tile.
Reply to Tiling Concern and Need Some Advice. TIA! in the DIY Tiling Forum area at TilersForums.com
Hi, We're currently adding an en-suite to a downstairs bedroom, everything is going well so far...
Hi there Homeowner here who recently had my kitchen tiled by a professional tiler. We’ve been...
Evening, Hope this post is in the correct section. If not, please feel free to move! I'm...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Tilers Forums on FB
