Tiling Tool Suppliers
Discuss 1 time use tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Hi guy's go easy in a newbie here 1st post I live in a council house and have decided to lay tiles 9mm ceramic in the kitchen as I will be wasting my time and money on a council property I still would like it to be tidy. This is a one time job only so I have to buy a cutter at least 600mm long I've seen a couple of cheap ones vitrex and josokit after the job is done it will be left to die in the shed so will this be OK for a one off job or is there something better for around the same money as those 2 Screenshot_20200403_173050_com.android.chrome.jpg Screenshot_20200403_173015_com.android.chrome.jpg
Hi guy's go easy in a newbie here 1st post I live in a council house and have decided to lay tiles 9mm ceramic in the kitchen as I will be wasting my time and money on a council property I still would like it to be tidy. This is a one time job only so I have to buy a cutter at least 600mm long I've seen a couple of cheap ones vitrex and josokit after the job is done it will be left to die in the shed so will this be OK for a one off job or is there something better for around the same money as those 2 View attachment 112375 View attachment 112376
Hi bud,
Never used those brands (and doubt anyone else on here will have). If they are ceramic tiles then they will probably be okay, but if porcelain then definitely NOT.
Alternatively, get a cheap angle grinder and a suitable disc such as these:
If you have any awkward shapes to cut then you would need a grinder (or wetsaw) anyway.
Plus, you might get some use out of it for other future (non-tiling) jobs.
If you already own a grinder then just get the disc for a fiver = money saved.
If the tiles turn out to be porcelain then get a diamond blade specifically for porcelain (much, much harder material than ceramic), or rent a professional quality dry cutter (Sigma or Ruby).
Good luck with the job, all the best,
Boggs
1,118
Uk
See if you can pick up a second hand Rubi ts60 usually loads on gumtree or eBay, you could sell it on again afterwards for the same.
Although collecting might be a bit of a problem at the moment.
Reply to 1 time use tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
I need advice on score and snap cutting of large porcelain tiles, lets say, over 1000 mm long...
HI FOLKS. LOOKING TO EXPAND ON MY TILING TOOLS AND INVEST IN A WET TILE CUTTER. WITH SO MANY...
P
Hiya I know this was 10 years ago hoping you still use the same email address and get this...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
Popular Tile Cutter Threads
Swansea
What member type are you?
  1. Homeowner
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 2 1.2%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
