Discuss 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com.
Porcelain is porcelain, if they’re 10mm, then no different.
10mm on wall, 6mm on tile, trowel all the same way across shortest distance on wall and tile.
Bed in well.
You might find a suction cup would help with handling them.
What do you mean by '6mm on tile' ? I would normally back butter, are you suggesting more than just a thin coat?
Dumbo
Bed in well.
Question , why 10 mm then 6mm as opposed to 8mm and 8mm . Same bed thickness but use of only one trowel.
Is there something I'm missing .
Waluigi
I’m more talking about if the ridges happen to line up perfectly or not line up perfectly. It’s not very consistent. Two different trowel notches will naturally be staggered every time and in my experience will bed down better. Being honest though, it’s unlikely to really matter. A nice wet mix and as you say, collapsing the notches.
To the OP- as always, pry a tile off after it’s bedded in and see what you have.
acaciaguy
568
Warwickshire
Bed in well.
It’s not a size of tile I have fitted either. Interesting post. Do you mean when trowelling you would go across the wall when trowelling rather than top to bottom?
Reply to 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
  • Sticky
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Serole. Italy
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
